Results 1 to 6 of 6
Thread: MK4 Battery -ve terminal
    Nov 2009
    NSW
    Hi All,
    What tools are required to remove the negative terminal on the MK4 Battery?
    Just getting ready to install a new stereo headunit.
    edit, if I am just taking out the old VWw headunit and putting a new pioneer head unit, do I even need to disconnect the negative terminal first?
    Using ISO plugs and plug and play harnesses.
    Thanks,
    K.
    Jul 2007
    Brissy
    10mm socket will sort the battery
    You could leave it active but best to remove it.
    Sent from my C6903 using Tapatalk
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Nov 2009
    NSW
    ok thanks
    Oct 2013
    Eastern Melbourne
    Always disconnect the battery terminals when working with electronics. You've got exposed metal and a nice 14.4v's of power running through the system. You don't want to short anything - these cars have highly complex electronics.
    Quote Originally Posted by MightyCarMods
    I'd rather lose by a mile because I built my own car, than win by an inch because someone else built it for me. Your car is your story, so don't let someone else write the book.
    -| "Laura" - 2001 Bora 4-motion (now sold) |-
    Mar 2010
    Lesmurdie
    Remember that the yellow and red wires need to be swapped in order to keep the stereo on if your using the ISO connectors. Just switch it in your adapter.
    2001 Turbo! 4mo Bora 'Boring' | Carbinaro CAI | Fixing broken stuff | Sorting the Turbo Goodness! | BBS Lm's 18x8.5 | KW V2's | 4 pot Brembo's
    Nov 2009
    NSW
    Ok thanks.
