Results 1 to 7 of 7
Thread: Mk4 agu sump talk
    Jan 2010
    Melb Westsideeeee
    Question Mk4 agu sump talk
    Hey guys,
    I've smashed the alloy sump for the second time now and the second time left me in a huge pickle stuck in the middle of no where haha. Anyway, what options are there? It is running in a mk1 so engine spacers are out of the question. I'm mostly looking at some sort of shortened sump idea. What's the most a sump can be shortened whilst remaining oem oil capacity?
    I've heard a while back ppl run other steel vw sumps and weld in a provision for the turbo return.
    I can weld steel myself, so any diy for what steel sumps there are that can work and how much it can be shortened would help heaps.
    Any personal experiences?
    - Brown U.S import 81 cabby
    - 88 Honda crx b18cr
    Sep 2009
    brisbane
    If I was to go any lower Id be looking at getting one of these
    403 Forbidden
    By definition, if you shorten it, the capacity will be reduced. Just running the same amount of oil will have the crank beating the oil which isn't good.
    You can probably use a steel sump and weld extra capacity to the back of it.
    Dec 2008
    Sydney/Canberra
    As above, if you can do a low profile one that is winged and baffled, you'll be OK.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jan 2010
    Melb Westsideeeee
    Quote Originally Posted by Lito View Post
    403 Forbidden
    That did a bit more research on that, turns out it's not necessarily and shallower, it's just got a metal casing. Looks pretty good actually. However still needs modifying for return line which is costly when welding alloy
    What steel sump would fit dude?
    What steel sump would fit dude?[/QUOTE]
    Sorry, I am only guessing that a steel sump off a mk1/2/3 might fit. I have no idea if they do or not. Just be easier to find and weld.
    Jan 2010
    Melb Westsideeeee
    Hmmmmm from past experience I know most vw stuff is interchangeable. Anyone know where mk1-3 steel sumps fit mk4?
