Results 1 to 4 of 4
Thread: Mk4 2.0L Engine Stopping - ECU Fault
    Dec 2019
    Hey Fans,
    I purchased a MK4 for my son and it has been great until the engine just quits . It will start again when cooled a little . drive for a bit , then stop again . I plugged in handy dandy code reader expecting crank angle sensor or coil pack and it reported no faults . However , we trouble shooted on the weekend by letting it idle until it quit , then plugged the reader in . It could not communicate with the computer . After 10 mins , communications were re-established and the engine would start again.
    After consulting the Google Gods , it seems that the ECU may be faulty ( random engine stops and inability to connect a reader when this happens ) .
    Any input here for MK4 owners ?
    Also purchased VAG-TAcho from ebay , but it will not connect to the cable and software had virus.
    Any recent recommendations for a VAGTACHO , as I know ill have to re-programm the IMMO if I need to swap the ECU.
    Or... Am I up for $299 US for the Rosstech unit ?
    MK4Dad
    Apr 2014
    Penrith, NSW
    PM IanGPonzaga on here, he'll be able to give you a hand with any programming.
    Albury, NSW Australia
    Have you had any luck mk4dad?
    My GTI has the same issue and a genuine new ECU + labour is getting close to 50% of the value of the car.
    It’s alive! (?!?)
    I might have fixed the issue with my GTI. I bought a used ECU and physically transferred the immobiliser chip.
    The car has been idling for about an hour since and seems fine. No error codes and no stalling.
