Results 1 to 10 of 10
Thread: MK4 2.0 black smoke. Airflow meter?
    Mar 2009
    Hey guys, just wondering if anyone can help or has experienced something similar.
    About 6 months ago, my Golf started to idle roughly, blowing black smoke and emitting a strong exhaust type smell from under the hood which would also enter the cabin. It was using 3L/H at idle too. I took it to the dealers and they replaced the Airflow meter. This fixed the problem and the car ran better than it has in ages. Until 2 weeks ago, when it started to show exactly the same symptoms again. Just wondering if it's possible the new airflow meter could already have died or if it may be something else like the O2 sensors? Is there any way I can test the airflow meter without the use of VAGCOM?
    Nov 2006
    Largs Bay, S.A.
    Check the obvious things like hoses, connections etc, then save yourself a whole lot of hassle and get it scanned ...
    Best Wishes.
    Dec 2008
    Northern Suburbs
    coolant temp sensor is your most lickely cause
    Mar 2009
    Cheers guys. Is the coolant temp sensor something I could replace myself? Any idea how much one would cost?
    Oct 2010
    Yarra Valley, VIC
    Quote Originally Posted by Colvs View Post
    Sensor costs $78 from VW Burwin from memory, not hard to replace either. I took it to my mechanic, it took him about 4minutes to change. That included time finding it.
    2014 MK7 R
    2014 Audi SQ5
    2022 Tiggy R
    2022 Tiggy 162 Allspace
    Mar 2009
    Quote Originally Posted by sirmoe View Post
    Thanks heaps!
    Apr 2011
    wollombi, NSW
    yeah, my GTi had the same problem, i asked vw and they helped me **** all and my car still does it, so thanks for the help
    Mar 2011
    is it drinking the fuel like no tomorrow?
    if so i iad the same prob on my 2.0 .....ended up being an o2 sensor. might wanna get a diagnostic check on it and it willl show if it isnt functioning properly
    Mar 2009
    Quote Originally Posted by zakkus View Post
    Yeah, it's using WAY more fuel than normal. I'm gonna have to take it back to the stealers to have them check it. Hopefully it is the airflow meter again because it will have 2 years warranty on it and should not cost me again.
    Thanks for the help guys!
    Dec 2008
    Northern Suburbs
    two years warranty on their work not on electrical parts, unless theirs some kind of special situation. If you have done a airflow meter already i highly doubt you will need one again. If your skeptical then get it scanned.
