Results 1 to 10 of 11
Thread: MK4 1.6 Brake upgrade question
    Nov 2013
    Goldcoast QLD
    Lightbulb MK4 1.6 Brake upgrade question
    Hey all , just a quick question , i did the front brake swap for the stock 1.6L AKL brakes to the 1.8T AGU GTI brakes
    the whole system was flushed and bleed twice by my mechanic, now my pedal feels soft , not spongy and sinking to the floor but soft they still work but i have to push the pedal harder then before and the pedal isn't as firm as before , has any one else come across this ?
    the only thing i can think is either the master needs to be swapped out for the gti one or my tiny motor doesn't make enough vacuum to make my pedal firm with the new bigger brakes ???
    any input of advice would be great
    Cheers Aaron
    Nov 2013
    Bathurst
    did you replace with brand new pads & rotors? if it stops well but the pedal is spongy i would be inclined to think it's the pad bedding in. mine came good after about 100km of city driving. possibly it could be vacuum as you suggested.
    01 MKIV GTI ME7 converted hybrid k04
    08 MKV GTI Daily driver duties
    I have serious VAG issues.
    Nov 2013
    Goldcoast QLD
    i used the pads that where in the calipers when i pulled them off the car as the pads where only a few thousand k's old as where the discs , i had the discs machine and the pads where scuffed up before putting them in , i dont know if its just me getting use to them or if there are improving but they do seem to be feeling a little firmer today
    Nov 2013
    Bathurst
    Give it a couple of days, I'll take a guess it will get better
    Nov 2013
    Goldcoast QLD
    I'm going to take it for a long drive tomrrow and try bed them In a bit see if it helps
    Erskineville, NSW
    Nov 2013
    Goldcoast QLD
    I have all ready done this , twice infact , they do seem to be coming better the more I drive it but still no where near as firm as my old brakes where ....
    Erskineville, NSW
    what diameter brake master cylinder is yours compared to the GTI version?
    Did you just pump bleed it or pressure bleed?
    Nov 2013
    Goldcoast QLD
    Not sure going to check that tomorrow , they where vacuum bleed then pump bleed again
    Dec 2008
    Sydney/Canberra
    Could be down to the quality of the pads and rotors you're running.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
