Just to clear somthing up.
If you do it by the book & legally, you can't put an older engine into a newer car at all under ADR's & engineer's.
Eg., you can't fit a VN 5L into a VS 5L, you can't fit a HK engine into a HG etc.
You can't fit a 86 KR 16V into a 88 model.
But this is only if you do it by the book.
Why would you fit a VR6 into a Mk4 anyway.
It's already been stated that a lightly tuned 20VT will pump a VR6!
Also, if you planned on 4 motion gear, you will need a the entire Bora to cut the floor out to fit a AWD stuff. Waist of time.
If you want a VR6 in a mk4, buy a bora!
