It's fairly common to have only a single rear foglight.
Hi guys,
My car has front and rear fog lights, but on the rear only the right side works. I have replaced the bulb to no effect, and on checking the socket it has no power.
Is this a standard thing with Golfs? Does the Australian model only have one working rear fog light, or is there a damaged wire somewhere?
Before anyone says "never need them in Australia", I generally agree, but I'm one of those folks that likes everything in my car to work, whether or not I actually use it!
Nothing to see here...
Yes only 1 fog.
There is a fairly easy mod to get the other one to work. Also a 5 light break mod turns 2 fogs into break lights.
Have a look on the 'Tex
http://forums.vwvortex.com/zerothread?id=1835863
MK4 GTI - Sold
MK5 Jetta Turbo - Sold
Awesome, cheers guys.
If it's not meant to work, then I'm not going to go out of my way to get it going. Just a bit odd that all the wiring and sockets are in place for nothing.
mine worked straight up, a large number of globes went out so we went on a replacing spree to find i was missing one, put a globe in and it works! i think as you'll see else where that some cars need to be wired up.
'04 BMP MkIV R32 #144
search getnew
