Results 1 to 7 of 7
Thread: MK IV needs new battery
    Gold Coast
    Hi Guys
    My MK IV has been hard starting latley, I did put a trickle recharge on her last month and it did come up, but last week it was just turning over and today it didn't start
    I noticed it is a "recessed" type and not a "flat top" battery, can you buy after market or do you have to buy form VW dealership - I have a VARTA in mine.
    If anyone has had his sad experience in changing batterys can you please let me know...where to buy, best price etc
    Thank you
    Jul 2007
    Brissy
    I got mine from battery world. It was in stock and cost about $160 with 3 year warranty.
    Install is fairly easy. Remove the battery terminals, fuse panel and battery cover.
    There is one bolt down the front with a retaining plate, 15mm bolt I think. The battery terminals are 10mm.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Apr 2008
    Canberra
    I got one from Battery World last year. I think they have two that will fit, same physical sizes, but different CCA's. i opted for the cheaper off the two as the golf isnt that hard to crank over i figure the extra was a waste of money better spent on batteries for my other cars.
    Like JustCrusin said, its an easy swap, should only take about 5 mins. i spent 4 of the 5 mins getting the fuse panel off.
    ~~~~____~~~~~~~~~_\_____
    ~~~ /_|__\__~~~~~~ / //__|__\___
    ____( )|__( ) ]_MKI ___[(' )__|___( ) ]_MKIV__
    Apr 2008
    I'm seriously considering a battery relocation and replacement with an Optima Yellow Top...
    Nothing to see here...
    Gold Coast
    Thanks guys
    I will check out Battery World
    you sure it's the battery and not something else?
    6 months ago my car wouldn't start, i call NRMA, and he just cranks it over for about 30 seconds, the display comes up as "STOP - OIL PRESSURE"
    and then it finnaly starts up. something to do with not enough oil pressure buildup in the hydraulic lifters.
    So not sure if it's a sludge build up problem, oil sender or oil pump problem, but lucky me, it apparently happened again last night just before something important was supposed to be done to it
    Dec 2007
    Brisbane, Southside...
    I picked up the exact type I needed from Autobarn when mine died. 550CA or something like that from memory and it had a three year warranty as well. Good price too.
    Unless your running wicked doof doof or similar I reckon an Ultima is overkill.
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
