Results 1 to 5 of 5
Thread: where to get a Vagcom?
    Mar 2010
    mullumbimby NSW
    Just wondering im new to these forums hope im askin the right questions in the right place. Just hoping to get some information about the best way to source a vagcom to hook up to my PC for diagnosis on my gti which one, best place to buy, how much? will it work on my T4 transporter? so many questions ive had a little look o ebay and am a bit reluctant to buy from overseas. any one have any ideas that would be a great help. ta mont
    Jun 2009
    Dubaddiction has them.
    Don't buy the cheap copies from ebay.
    Nov 2007
    Perth
    on http://www.dubaddiction.com.au/index...0ugrptfjnmo3t7
    it says it's designed for the golf5 platform, is it still fine for our 4's?
    VCDS (VAG-COM Diagnostic System) License with Micro-CAN Interface The enthusiast's interface you need to turn any PC with an available USB Port into a powerful diagnostic tool for MK5 based Golf Technology Models.
    Features:
    Low-cost interface designed exclusively for use on cars based on Mk.5 Golf technology. This interface is not backwards compatible with older cars using K-lines for diagnostics, and it is not compatible with some Audi models. See the Micro-CAN technical page for a list of compatible models.
    Acts as a "dongle". No "Software Activation" required! When used with this interface, VAG-COM is always fully-functional on any PC that meets the requirements.
    USB connector plugs into most modern laptops! (USB 1.1 or 2.0)
    Bi-Color (red/green) status/activity LED
    12 month guarantee against defects.
    Yep, the micro-can version won't work for Mk4
    You need the HEX-CAN-USB version
