Results 1 to 10 of 11
Thread: Mk 4 GTI golf running on 3 cylinders
    Oct 2013
    Buderim Qld
    Hi All, As per the title my 1.8l golf is only running on 3 cylinders. So far I have checked/replaced: Replaced coil packs (4),swapped position of spark plugs, checked injectors and swapped positions, checked injector wiring with light,carried out compression test, all similar. Has anyone had experience with this problem before?
    Any/all help will be appreciated.
    Woodgrub
    Jan 2011
    Gold Coast, QLD
    Ignition module found in the air box
    Your coil packs would have been fine, they rely heavily on the ignition module.
    Oct 2013
    Buderim Qld
    Hi Sirocco20348, Thanks very much for the information. Is it repairable or throw away and buy a new one from? (any suggestions) Hoping I can return coil packs.
    Cheers and thanks again
    Woodgrub
    Jan 2011
    Gold Coast, QLD
    I just bought another one.
    There is a thread that details how to fix it, but you have to cut it open with a knife etc.
    http://uk-mkivs.net/topic/51078-repa...-351-icm-unit/
    Depends how keen you are.
    Apr 2014
    Penrith, NSW
    Great link Sirocco.
    Not that I have a 1.8t but I'm assuming all the ignition modules work the same and I'm a tight ass so that's great info.
    Jul 2007
    Brissy
    Before replacing the ICM, check the connector. I found that a pin had come loose and would push back in a bit.
    With the engine running wiggle the harness and see if you can make any difference.
    I did have to replace the ICM twice on my GTI. At about 190,000km the connector became an issue. Once reconnected correctly it was fine.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Oct 2013
    Buderim Qld
    Hi Justcruisn and Sirocco, Thanks for your help. After reading the reply from Sirocco I cut the ICM apart and yes one wire had come off but when I started to wriggle the others also came off and even one on the transistor which I couldn't fix so I have ordered a new one. $400 and some thing on discount to me down from $600 and something at Bursons in Maroochydore.
    Thanks again,
    Cheers,
    Woodgrub
    Jul 2007
    Brissy
    I think the last one I bought was around the $100 mark.
    MK4 GTI - Sold
    Jan 2011
    Gold Coast, QLD
    Quote Originally Posted by Woodgrub View Post
    Thanks again,
    Cheers,
    Woodgrub
    That seems excessively expensive. There is no way I big paid that much for mine. I bought from eBay and it it was Meyle branded. I swear it was $100.
    Munno Para West Adelaide
    100 sounds about right for oem, 400 is ridiculous!
