Mk 4 golf started running rough
Hi All, Started my golf at lunch time after driving 3 k's this morning, now running very rough. Any suggestions?
I fitted new plugs a few k's ago so would think they should be OK, Power pack ?
Any help will be appreciated.
Woodgrub
Seen you’ve changed the plugs recently, I would double check you’ve clipped the coil packs back in correctly, then check if one of them is faulty by unplugging one whilst it’s running, unplug MAF. Scan it. Check vacuum leaks. Etc
Thanks HaydEn, I will try your suggestions.
Woodgrub
- You may not post replies
- You may not edit your posts
Forum Rules
