On newer ECU types it'll pick a cylinder but not on your Passat AFAIK.
As you have the ignition amp in the airbox, the ECU can't tell which one isn't working.
Even on the MK1 TT as an example, I have seen every coil die following a flash, yet only one actually registered as a hard fail.
I'd be more suspicious of the ignition amp on your motor over a bolt down coil pack. They are like 500 bucks from the dealer!! Quite easy for just one cylinder to be down so it runs like a WRX.
