Page 2 of 2 FirstFirst 12
Results 11 to 19 of 19
Thread: Mirror Adjuster
    Apr 2006
    Hobart,Tas
    Its a common fault. About $65 is right. I have always removed the door trim to get them out so as not to damage the trim on the door.
    May 2007
    Jimboomba. QLD
    Passat adjuster
    Hi All,
    I'd be keen to see what the Passat one looks like.....it appears that almost everyone here has broken at least one mirror adjuster knob so if the Passat one is different, it might be a good idea.
    I guess one of us could post a question in the Passat section and see if we can get a pic, before we all rush out and buy one each.
    2010 90TSI Manual / Comfort Pack / United Grey
    RICE - Leave the useless wings to the Penguins...
    Aug 2006
    i would take a pic if i knew which part ur talking about..
    May 2007
    Jimboomba. QLD
    Mirror adjuster
    Hi,
    It appears that many of us with MK4s have an issue with breaking off the adjustment knob for the rear view mirrors. It is a small knob on the door trim where you select either left or right mirror and then use the knob as a kind of joy stick to adjust the mirror. It was mentioned earlier that the Passat B5 has a different arrangement...similar system but no knob for adjusting the mirrors.
    If it was a straight swap, it might be a great fix for an obviously common fault with the Golf. If you could help, that would be great.
    Thanks
    Aug 2006
    oh the side mirrors!!! man i thought u's had a knob for moving the rear view mirror (the 1 on d front wendscreen)
    yeh the passat 1's are buttons up, down, left, right
    Aug 2006
    attached is d thing
    gpk_gti Guest
    much nicer!!!
    May 2007
    Jimboomba. QLD
    Much nicer
    Hi All,
    certainly looks a lot less fragile than the joy stick on the golf.
    It looks like we would need to replace the trim around the door handle as well as the adjustment switch.
    I am wondering how closely the wiring matches between the Golf and Passat.
    Could be an interesting little project for someone to try.......if no one has tried it already.
    Mar 2007
    sydney
    Quote Originally Posted by craig_the_german View Post
    Hi All,
    adrian to the rescue http://forums.vwvortex.com/zerothread?id=2749339
    mk4 the mods begin for round 2 hahahha
