Page 3 of 8 FirstFirst 12345 ... LastLast
Results 21 to 30 of 71
Thread: Maximum front/rear tyre width difference for 4motion?
  1. #21
    Jun 2009
    Melbourne, VIC
    Only problem with that calculator is isnt doesn't do stretch
    His bora is going to be fair low to fit those wheels so i doubt 255s with cut it...
    Yup will need stretch. Stretching a tyre doesn't change the rolling diameter does it? I thought it only stretches the sidewalls out and the effect on rolling diameter would be negligible?
    VW Bora V6 4motion
  2. #22
    Quote Originally Posted by jpflorez View Post
    does a touch, but not something worth calculating, as you said.
  3. #23
    Jun 2009
    Melbourne, VIC
    Found a place that will do KU31s in 235/40/18 all round for $800 (including stretching). Price seems decent. Just trial fitted the front wheel today as I've been lazy and it's rubbing on the calliper. Looks like I need a small spacer for the 18x8.5 +30 fronts..
    VW Bora V6 4motion
  4. #24
    will be keen to see how u go with the spacer on the 8.5et30, thats what i currently have and am looking at putting a 5mm spacer in to trial
  5. #25
    Aug 2011
    Canberra
    Tyre Pressures will affect it, but 225/40/18 Fronts will match quite nicely to 255/35/18 Rears
    Rim Radius - 228.6mm
    Sidewall 225/40 - 90mm
    Rolling Diameter 225/40 - 2001mm
    Sidewall 255/35 - 89mm
    Rolling Diameter 255/35 - 1997mm
    So Running the Rears 2psi harder than the fronts will probably resolve this...
    Also, as there is more weight over the fronts, the rolling diameter is actually slightly smaller.
    Good tyre size comparison site: Tire Size Calculator - tire & wheel plus sizing
    '90 Mk I Cabriolet 1.8L - My toy... err... Daily driver... - Replaced with ‘93 Mk1 Cabriolet 1.8L <- Soon to be mine...
    '99 Mk IV Bora V5 <-- RIP - Replaced with ’10 Tiguan 147kw <-- Wife's Daily Driver
    '05 Volvo T5 S60 - 2.5L Turbo AWD Replaced with '09 Ford LV Focus Sedan <-- Used by the kids
    '07 Eos 2.0 TFSI - Project Eos...
  6. #26
    Jun 2009
    Melbourne, VIC
    Quote Originally Posted by Shadow_Rusty View Post
    I know but the problem is price and fitment under the guards. Those irregular sizes cost $100 more per corner at least, and then the rears will be hard to fit.
    I trial fitted my rear wheels (18x10 +25) and it fits the same as the fronts.. Rubs on the calliper but also the stock strut. I don't know if once the KW coils are installed it will make it worse or better. Should be better but I haven't even opened the box yet. My mate has some cheapo 8mm spacers I will try out.
    Also since I'm only trial fitting on one side the left and right sides of the car should be the same right??
    VW Bora V6 4motion
  7. #27
    are 4mo offsets different to the 2lt bangers? this is the second case of wheels no fitting. or are peoples wheels just the wrong offset...?
    my 10s arnt as aggressive as those and i dont touch the rear strut or ever the dust cover on it.
    Id imagine itll be worse becuase the wheel will camber in on the rear?
    Should be the same... however mine are different by a few mm, passenger side my current setup is flush, where as the drivers side pokes a touch. but that could be put down the body damage or rear beam being off centre.
  8. #28
    Apr 2011
    Ipswich, QLD
    The 4mo has independent rear suspension same as the R32 so camber and fitting will be a little different than the FWD versions, obviously lowering will increase the camber and thus strut clearance issues.
    Of course I could be hugely wrong but this would be my best guess.
    2003 Bora 4Motion
  9. #29
    yep id say your right about the rear.
    The front would be the same setup though...?
  10. #30
    Apr 2011
    Ipswich, QLD
    I guess the front would be the same, not sure about the offset on my wheels but they are 18x8 with 225/40 on them and i have about 5 mm clearance for the fronts to the strut.
    2003 Bora 4Motion
