Something else - the suby's were set up with pre and post solenoid restrictions to get the desired boost characteristics. Some had restrictor pills hidden within the tubing on the solenoid inlets, outlets to the actuator and also the bleed line back into the TIP. Some even had combinations of all three. Once you get the correct inlet restriction to your N75 and you are satisfied its all fluffy, you can ditch the MBC and just have a neat restrictor hidden inside the tube that replicates it.
