Major Service + Extras - Self Imposed...
Hi All,
A few weeks ago when I had the golf up on the hoist to replace front rotors, we noticed a drop of green coolant that seemed to be directly under the water pump area. So, thinking it's best to nip it in the bud, I am replacing the water pump, timing belt, and the rocker cover gasket, which is also now leaking a bit more. I'm doing it this Saturday (my good mate the qualified mechanic is), and I was wondering if there was any info/advice out there on anything I need to look out for, or any parts I'd missed?? I will have alreday bought about $500 worth of parts by Sat, so not keen to spend too much more as I may sell to get a gti down the line.
Here's the car stats and the parts list, feel free to add any constructive input!
Car:
2000 MK4 Golf 1.6L, 5sp Man, 135000 kms, Engine: AKL, Anything else???
Parts - Already Bought:
VRS Kit - Basically a head/rocker cover gasket kit, where I'll replace the rocker cover gasket and all other inlet/outlet gaskets along the way, using all/most except the head gasket.
Timing Belt Kit - Timing Belt, Timing Belt Tensioner, 2 seals,
Water Pump - Plastic impellar, I asked for metal, but plastic turned up, can refund if I want.
Thermostat - plus o-ring/gasket.
Parts - To Buy:
Oil - Looking at Mobil 1 ESP 5W30, avail at GLLubrication, 5L = $65, +post = $80.
Oil Filter - no idea, suggestions?
Coolant - old is green, so looking for G12++ or whatever it's called, will have to flush old,
Anything else?
Notes - I'm not sure if this oil is for a more 'perfect' engine, and I might need something thicker? or is this high end oil providing the protection I need. I guess I'm just worried about the oil being too thin on a car that is already pumping out oil up through the rocker cover gasket.
Was thinking of doing an oil flush, but don't know much about it.
Dark Grey Mk4 Golf, 1.8T GTI conversion, APR stage 1, stock air intake, FMIC, 3" to 2.5" Exhaust, FK AK Street Coils, Black 18" (Avant Garde M310's ?), tinted tails, ...
