Results 11 to 20 of 24
Thread: Major Service + Extras - Self Imposed...
    Jan 2009
    For your car, any oil must have at least one of these specs on the label:
    VW 502.00 or VW 504.00
    For viscosity grade, stick with 5W-30 or 5W-40.
    But I think you might be better off with a 5W-40 oil, given the car's age.
    Newcastle, NSW
    Quote Originally Posted by Diesel_vert View Post
    Awesome! thanks for the reply mate!
    I will definitely look for the VW certification numbers, but just wondering about the grade...
    I looked up the Mobil 1 site (def not only looking for mobil), and it suggested the oil for my car is: Mobil 1 0W40.
    What is the difference between 5W40 and 0W40 ? There's also a 'High Mileage' Mobil oil that's 10W40, so what's the diff?
    Mobil site: https://www.mobiloil.com/usa-english....aspx?option=1
    It looks like with the time constraints, I'll have to get either mobil oil from GL Lubricants, or other brands from 'standard' places like: repco, supercheap, autobarn, etc.. Unless there is somewhere better on a Sat Morn?
    GL Lubricants / Mobil: Mobil Pricelist — Top Grade Oil at Lowest Price
    Again, BIG thanks!
    Dark Grey Mk4 Golf, 1.8T GTI conversion, APR stage 1, stock air intake, FMIC, 3" to 2.5" Exhaust, FK AK Street Coils, Black 18" (Avant Garde M310's ?), tinted tails, ...
    Jan 2009
    Quote Originally Posted by kenbot View Post
    Basically, you need to use an oil with a HTHS of more than 3.5, otherwise it'll be too thin for your engine. Hence, VW 502 and 504 prevents you from using oils that are too thin, irrespective of viscosity (that's really the only reason why I said to use 502 or 504 oils).
    All ACEA A1/B1/A5/B5 oils have a HTHS of <3.5 (which rules them out) and all ACEA A3/B3/B4 oils have a HTHS >3.5 (which VW 502 and 504 is based on).
    Viscosity rating itself is not a sufficient indicator. For example, M1 5W-30 ESP has a HTHS>3.5 (acceptable), but M1 5W-30 has a HTHS<3.5 (unacceptable).
    The first number indicates how well it flows when the engine is cold (lower numbers flow better and vice versa).
    The second number indicates the viscosity at operating temps (lower numbers are thinner, and vice versa).
    A 0W-40, 5W-40 and 10W-40 will roughly have the same viscosity at operating temps, but the 0W-40 oil will flow better when the engine is cold, followed by 5W-40, and then 10W-40.
    Given the same price, I'd go with M1 0W-40, but any synthetic 5W-40 oil will be fine as well. And unless you're experiencing significant issues with oil consumption or leakage, then you don't really need a 10W-40 oil.
    Newcastle, NSW
    Awesome! Mega Thanks!!!
    Jun 2011
    Canberra
    Hey mate,
    On my last service (exact same car as yours) I used the Castrol Edge 5W-30 A3/B4 from repco and seems to be fine. I'd also reccomend getting some injector cleaner fluid. Basically just add half the bottle in your tank when it's empty and put a full tank of high octane petrol in.
    Newcastle, NSW
    I've ended up getting:
    Penrite, HPR 10, full synth, 10W-50 (10W-40 class), VW 502.00/505.00 .
    - k
    Jan 2009
    Should be okay, but TBH, I think that's too thick.
    Newcastle, NSW
    Does the VW rating not make it useable? especially for an older car?
    What would/could that do?
    Adelaide hills, SA
    I would use the HPR5 5W40. Use HPR10 only if the engine uses too much of oil.
    Jan 2009
    Using oils that are thicker than necessary (in a healthy, well functioning engine) might result in higher operating temperatures and reduced fuel economy & responsiveness due to increased friction. Also, in the case of HPR 10, it's not as free-flowing when starting up from cold.
    No, no, you can still use it, but it's my opinion that a 50-weight oil is too thick for your engine - but you certainly won't damage it.
    This...
    If we're sticking with Penrite, I too would recommend HPR5 5W-40 over HPR10.
