Page 2 of 2 FirstFirst 12
Results 11 to 13 of 13
Thread: MAF Problem?
    Aug 2007
    Ok if you check your O2 sensor and the stat is stuck open it will be reading rich along with a longer duty cycle on the injectors, all checkable with measured blocks on Vagcom. If you still query the o2 sensor pull the vac line off the fuel pressure reg then itll richen, blanking off the vac at the same time. Now check it for lean switching, create an air leak. All very checkable with Vagcom. You mention the fact its at op temp well the system is on closed loop then.
    good luck with tests
    Jmac
    Alba European
    Adelaide hills, SA
    Quote Originally Posted by Jmac View Post
    Jmac
    Hey there, Jmac.
    All we need now is his car.
    Aug 2007
    Hey there, Jmac.
    Haha true story mate
    cheers
    Jmac
    Alba European
