well mk4s have bolts not nuts.
Iv always done mine by hand.
rattle gun on the FT setting is also good if youhave a breaker bar to remove them later
Just wanting to know how tight should the bolts be? Tight enough to be undone by hand?
90Ft lb on a Passat with Mags
If you get stuck on the side of the freeway with a flat you'll want to be able to get them off by hand.
Even in a body shop I usually finish doing them up with a wheel brace, rather than over tighten with a rattle gun so noone can ever get them off again
Ohk, cause i was applying plasti dip on my rims and got the back ones off but the front wheels seem to be stuck. I used a rattle gun as well but still didn't work, which got me to think about how tight bolts should be, i guess them being unable to come off is too tight ...
