Results 31 to 34 of 34
Thread: Lowering and Wheels (new to site)
  1. #31
    Sep 2007
    if you wanna go that low, coilovers are your best bet. also, sydney ruts = coilovers up, cruising down through the national park = coilovers down.
    also, did you say you wanted to do some serious work to the motor in time to come? it's a lot more expensive to work on a 2.0 8v NA, as compared to the gti which comes standard with a turbo motor.
    87' MK2 GTI
    13' MK7 TDI
  2. #32
    Mar 2007
    sydney
    if your planning to go shocks & spring...might as well go coilovers as some of the other guys have mentioned. make sure you get the right info on how low you can go with the coilovers.
    2004 GTI, GIAC, DOWNPIPE
    2007 R32 3DR MANUAL
    2010 NAVARA D40
    2016 Q7 4M 200kw
  3. #33
    Canberra
    Something you'll have to factor into the budget as well is changing the front sway bar, if you go lower than about 40mm (1.6") it's almost certain the stock bar will hit on the drive shafts.
    Snowy.
  4. #34
    Sep 2007
    coilovers and swaybars go so well together anyway.
    with hottuning, the ones matt has, they go quite low.. infact, lower than h&r ultra low. so like... if wheels, guards, clearances permit, 5"...?
    87' MK2 GTI
    13' MK7 TDI
