Results 1 to 8 of 8
Thread: MKIV at Home Service Question
    Mar 2011
    st kilda VIC
    Hi there,
    I recently purchased a "$49" car service coupon from Cudo to service my car (VW Golf 2001 Mkiv 2l engine, 8v).
    The deal seemend good, all free except fluids and parts. I called to get an estimate on "fluids and parts" and they said $500!! What a Scam!
    So i thought i would change fluids and parts myself and get them to do the service free.
    For 83.90*GBP = 131.292*AUD delivered from http://www.vwspares.co.uk
    I get :
    06A115561B Oil Filter
    1J0129620 Air Filter
    1J0201511A Fuel Filter
    1J0819644A Cabin Filter
    #19400 Coolant (G12++ type)
    My question is:
    Can a complete newbie install these parts himself with the aid of youtube and a service book for mkiv (which i am downloading now)
    and
    What tools do i need to buy (be as precise in names as possible please)
    Thanks for your help, Great Forum!
    Seb
    Jul 2007
    Brissy
    Quote Originally Posted by Seb View Post
    Fluids and parts = The Service
    Those 'service' vouchers have been around for ages and are always a rip off. I think Midas used to do them in Brisbane in the 90s. They use them to get you in the door and tell you all the things that need to be 'fixed' on your car and how they can't legally let you drive the car until you get them fixed.
    There are plenty of other things that you might want a VW specialist to look at for you too. Are their any oil leaks ? What condition are the spark plugs ? Have any fault codes been logged ?
    A trained eye will spot problems and save you in the long run.
    I generally fix things that break on my car and get my mechanic to do the service and inspection once a year.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Mar 2011
    st kilda VIC
    The spark plugs and oil filter were changed at the last service.
    I may get a service from a VW dealer however, in the interest of saving money, can i fit the parts listed myself (oil/ fuel/cabin filter?) without too much fuss?
    Jun 2009
    Melbourne, VIC
    If you buy all the fluids and parts yourself can't you just dump it on their counter with the voucher and say, "$49 service biatch!"?
    Or is it in the T&Cs that you have to buy stuff off them?
    Btw it can all be done by a newbie as long as you have the tools.
    VW Bora V6 4motion
    Mar 2011
    st kilda VIC
    It's in the T&C's taht you need to buy parts and oils off them. I think i will call and discuss precisiely what fluids i want, and make sure they source the parts at a reasonable price beforehand.
    HOWever, Do you believe i am able to change these parts on my own and what tools are required (never done car stuff before but can build a pc!)
    Jun 2009
    Melbourne, VIC
    Mate I'm a Network Engineer and I do these things myself so you should have no problems.
    I've got a V6 Bora so don't know the exact tools you need but there should be heaps of guides online.
    VW Bora V6 4motion
    Jul 2007
    Brissy
    Well it is all nuts bolts and clips like a PC
    You will need torx driver to remove under engine trays to access oil filter.
    Cabin and engine air filters just need a screwdriver.
    You need a big spanner or socket for the oil drain plug - not sure on the size 17 - 19mm ?
    Filter wrench for the oil filter.
    Ramps or axle/jack stands.
    How to change your engine oil - Do it yourself help - Supercheap Auto Australia
    Check out some DIYs for the other things, they are easy enough.
    http://www.vwwatercooled.org.au/foru...read-7540.html
    VWVortex.com - *** The MKIV How-To, FAQ, and Do-It-Yourself Guide - Please consult before posting***
    *** Updated DIY guides index *** - uk-mkivs
    MK4 GTI - Sold
    Mar 2011
    st kilda VIC
    those links are great thanks!
