Results 11 to 20 of 27
Thread: Lowering my mk4 R32??
    Jan 2007
    What shocks do you have?
    Gold Coast QLD
    Quote Originally Posted by Langers View Post
    Just standard, car now done 100k and they our original
    Jan 2007
    Quote Originally Posted by BHardstaff View Post
    The standard shocks were RUBBISH from new. You really need to replace them if you're going to fit springs that are any stiffer than stock or the car will be severely underdamped, particularly in the rear.
    Koni FSDs are a good option and not too expensive.
    Aug 2007
    Perth, Australia
    Awesome - KW Coilovers Variant 1 Basic Golf IV R32; (1J) 09/02
    Awesome - KW Adjustable Rear Control Arms TT Quattro/S3/4mo
    I'd spend the extra money and get the KW control arms.
    don't forget, if you order something from the UK you don't pay their VAT
    ---------- Post added at 10:00 AM ---------- Previous post was at 09:59 AM ----------
    Quote Originally Posted by schoona View Post
    my springs were ok when I first got them (used H&R for cheap to sort out a suspension issue). They have killed my shocks now so need both. Go coilovers first up!
    Same here
    1991 BMW 318is RED E30
    Jul 2011
    Wolfsburg, Melbourne
    Awesome thread! Perfect timing because I'm about to order some KW V1s and the adjustable control arms.
    One quick question though, do I order control arms for front and rear?
    MK4 R32 #80
    RED MOTION
    Aug 2007
    Perth, Australia
    Quote Originally Posted by Jeeren View Post
    All you need are rear lower control arms, the ones in the link i posted. Jack up the rear of your car and take a look. They go from the diff to the bottom of the hubs
    Jul 2011
    Thanks for the reply. All ordered, no backing out now
    MK4 R32 #80
    RED MOTION
    Oct 2010
    Melbourne, VIC
    Quote Originally Posted by balkanac View Post
    Same here
    As Langers had said, you can just buy decent aftermarket dampers if you've killed the OE ones with lowering springs.
    Thanks for the advice! Decisions decisions! Might take it to peddas? I have Hurd they are good?
    Some Pedders are good and some are ordinary - being franchises, it can be a bit hit or miss. Any place that you trust for a suspension alignment should be fine for fitting aftermarket suspension.
    Resident grumpy old fart
    Gold Coast QLD
    I just can't believe u can't buy anything over here and u have to get it in from the uk etc!
    200 MK4 R32s brought into the country and even when you add the MK5s,TTs and Bora's, its not a massive market. TBH it's a bonus having to import it, you save a fortune.
