Check out some of the forum sponsors for parts.
what model mk4 do you have? if it is not a AWD, and you plan to lower more then 40mm keep in mind you MAY run into problems with the sway bar rubbing on the drive shafts
Dpm performance in the uk also sells kw v1 - I got for $850 landed (basic, not stainless steel version) and I love them.
Only took 8 days to get here too.
Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
I have a display set of Golf 4 coilovers brand new, but been on display for a year $500
Thanks vr6man
We charge $200 for fitting coilovers, plus GST Plus $80 at the wheel alignment joint.
If I'm not mistaken the MKIV Golf GTI had lower suspension that the 2.0 version.
Cheapest option would be a used set of MKIV Golf GTI springs but then you don't mention how low you want to go.
I don't think that there is a need at all to have adjustable lower control arms. I've regularly gotten over 25K kms with my last few sets of tyres and I'm lowered enough where the rear camber is clearly visible.
MKIV Golf R32
BMP
#171 / 200
i got these still...
http://www.vwwatercooled.org.au/foru...uts-67687.html
'02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
