Results 1 to 10 of 15
Thread: lowering mk4
    Mar 2012
    lowering mk4
    hey guys im looking for the cheapest option to lower my golf mk4 2.0, im a student so i would like the best option on a budget. cheers guys
    Apr 2008
    How low do you want to go?
    If your existing dampers (shocks) are in decent condition and you don't want to drop the car too far, lower springs will only cost a few hundred dollars (get decent ones though).
    For more serious drops, you'd want to change dampers too, as going too low on a standard damper will cause you problems as you hit the bump stops. Alternatively, look at a set of coilovers - I know ECS are doing FK coilovers for the Mk4 for less than USD$600 before shipping (let me know if you want a quote on them with shipping).
    Nothing to see here...
    Jun 2008
    Cronulla, NSW
    I'm still convinced that a drop beyond R32 height demands twin sets of adjustable lower control arms to control camber and toe concerns - unless you love buying rubber every 10k kms.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Apr 2008
    Quote Originally Posted by Dyldo View Post
    You can probably go a little lower than stock R32 height, but not much, before camber/toe becomes an issue, but not much. When I was on the coilovers I was significantly lower, but toe was well within acceptable limits.
    Jan 2012
    I'm in the same boat as you besides the student part but am I tightass on this car.
    Im planning to get Koni sports and eibach prokit. I'm also going to get ecs refresh kit
    Sent from my HTC Sensation Z710a using Tapatalk
    Dec 2008
    sydney
    Don't forget to add fitting and wheel alignment to the cost.
    Coilovers will be the cheapest option, you can go as low as your spine or driveway allows.
    Give Matt at Camden GTi a call he has a set.
    I'll be going the shocks/coils/swaybar route, far more expensive but I think it will give me a more comfy ride while making the car a sweet handler.
    MK4 GTI: Custom Code Stage 2, K03S, 42DD exhaust, Bilsteins, whiteline F&R, 312mm brakes
    MK6 GTI: MY13, DSG , very stock
    Ducati 749
    Sep 2010
    Wheelers Hill
    springs and shocks are a cheap option and will give a slightly better ride than fk streetlines
    I used to have the fk streetlines, the ride handling was a huge improvement over stock and if you are on a budget I would recommend them
    You would be looking at around $400 for installation
    Audi A3 1.8 T
    aiming for 200kw atw
    http://www.vwwatercooled.com.au/foru...-8t-71747.html
    Jan 2012
    Will be diying so cost isn't a factor for me for install but 400 seams high shouldn't take no more than 2 hours if they know what there doing. Then a wheel allignment. 300 seams about right.
    You can get Koni strt. H&r sport springs plus ecs stage 2 refresh kit for 1000 shipped. I think that's pretty good.
    Dec 2008
    sydney
    I dont think antonn's budget will stretch that far ( only speculating) but agree that ECS have a good range.
    DIY will always save you dollars.
    @ antonn: cheapest way is a set of coil springs and DIY
    Ducati 749
    I have lowered springs on stock dampers on my Mk4, the ride is pretty bone-shaking at times, and it scrapes a lot. The sump is scarily close to the road too.
    I looked into getting KW V1 coilovers from Awesome GTI in the UK and it worked out around $950 landed (130 GBP postage), that's the way I'll go eventually.
