Results 1 to 10 of 15
Thread: lowering mk4
    Apr 2008
    How low do you want to go?
    If your existing dampers (shocks) are in decent condition and you don't want to drop the car too far, lower springs will only cost a few hundred dollars (get decent ones though).
    For more serious drops, you'd want to change dampers too, as going too low on a standard damper will cause you problems as you hit the bump stops. Alternatively, look at a set of coilovers - I know ECS are doing FK coilovers for the Mk4 for less than USD$600 before shipping (let me know if you want a quote on them with shipping).
    Nothing to see here...
    Jun 2008
    Cronulla, NSW
    I'm still convinced that a drop beyond R32 height demands twin sets of adjustable lower control arms to control camber and toe concerns - unless you love buying rubber every 10k kms.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Apr 2008
    Quote Originally Posted by Dyldo View Post
    You can probably go a little lower than stock R32 height, but not much, before camber/toe becomes an issue, but not much. When I was on the coilovers I was significantly lower, but toe was well within acceptable limits.
