Page 2 of 2 FirstFirst 12
Results 11 to 15 of 15
Thread: lowering mk4
    Feb 2007
    Somewhere
    Quote Originally Posted by antonn View Post
    hey guys im looking for the cheapest option to lower my golf mk4 2.0, im a student so i would like the best option on a budget. cheers guys
    If I'm not mistaken the MKIV Golf GTI had lower suspension that the 2.0 version.
    Cheapest option would be a used set of MKIV Golf GTI springs but then you don't mention how low you want to go.
    Quote Originally Posted by Dyldo View Post
    I'm still convinced that a drop beyond R32 height demands twin sets of adjustable lower control arms to control camber and toe concerns - unless you love buying rubber every 10k kms.
    I don't think that there is a need at all to have adjustable lower control arms. I've regularly gotten over 25K kms with my last few sets of tyres and I'm lowered enough where the rear camber is clearly visible.
    MKIV Golf R32
    BMP
    #171 / 200
    Aug 2011
    melbourne
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
    Aug 2009
    Dpm performance in the uk also sells kw v1 - I got for $850 landed (basic, not stainless steel version) and I love them.
    Only took 8 days to get here too.
    Platinum Grey mkV Jetta turbo, Viezu motorsport map, GT-CX 18", lowering to come
    Check out some of the forum sponsors for parts.
    what model mk4 do you have? if it is not a AWD, and you plan to lower more then 40mm keep in mind you MAY run into problems with the sway bar rubbing on the drive shafts
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Camden, Sydney
    I have a display set of Golf 4 coilovers brand new, but been on display for a year $500
    Thanks vr6man
    We charge $200 for fitting coilovers, plus GST Plus $80 at the wheel alignment joint.
