The Eibachs are probably a good choice given your concerns. 30mm is a nice drop without being far enough to start causing other problems. To be honest, on a MK4 if you go much more than that, although it might look good, it can affect the geometry to the point where handling actually becomes worse. Plus, once you get near 40mm or so you can have front sway bar/drive shaft rubbing issues.
Cheers,
Snowy.
