Ive done plenty in this era. If you buy from VW yes it comes cut to the vin and it has to be coded to the car, Vag com doesnt do it per se, you need to suck the pin code form the dash with other software, in a few forms actually. Some better than others and some hit or miss. This era of Vw i personally havent had a drama. back to the comment on the strip supplied on the fob, that left with the dinosaurs in MK3 era. MK3 different ball game, Immob is seperate from the cluster. Mk4 is in the cluster therfore we can extract it via the obd port. Technically if you are really stuck get a whole lock suite from another breaking VW and code it. 2 - Get your key from VW in 14 days cut to the vin, still code it with the extracted code. Also the comment on the key fob , nothing fancy about coding them. all i can say of you havent played with pin extracting software and plan to beware, you can lock out your dash or have it running with a nice key sign flashing on your dash, take it to someone who knows what they are doing
Jmac
