Results 1 to 10 of 10
Thread: Losing coolant, but how?!
    Jul 2011
    Hey guys,
    I've had the car warn me of low coolant twice now about a week apart and have had to top up the coolant by almost a litre each time. There are no visible leaks on the floor and the engine bay looks fairly dry apart from some oil so I'm confused as to where the leak could be. I'll be checking the hoses tonight to see if there are any leaks but I'm guessing if it was a crack/split hose it'd be a lot more noticeable... Is it possible the coolant cap might not be sealing properly so it's venting out through there?
    So many dramas with this car at the moment, it makes me sad :<
    Nov 2013
    GoldenGrove SA
    Which engine is it?
    Have you looked under the oil filler cap for any sign of white drops amongst black oil?
    Mar 2009
    Another point to check will be the O-ring that seals the Coolant sensor.
    Dec 2008
    Sydney/Canberra
    Have it pressure tested. It'll show up sooner or later.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2007
    Brissy
    A small leak may not be noticable when the engine is cold. As the coolant heats up and the pressure rises it can be forced out a small leak but will vapourise, you wont see any pooling.
    Look for pinkish powder around all joints.
    It is common for the junction at the end of the engine block with the sensor, above gearbox, to crack.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Quote Originally Posted by JustCruisn View Post
    This. Mine didn't even crack but warped off the block, it was only a tiny leak when hot, didn't leak once car had been parked and cooled
    Dec 2008
    Sydney/Canberra
    Yeah, and if you've got a cam cover leak, the oil will seap down and cause the o-ring to swell.
    '01 Beetle 2.0
    Jul 2011
    yikes, thanks for the tips guys, will take a look over the weekend to see if any of the above applies. hopefully it's nothing serious though, there's enough wrong with the car as it is!
    Jul 2011
    Looks like this is the culprit, took a look and there's a load of fluid sitting on my gearbox now and I can see coolant dripping down the side of the hoses.
    Any idea what the part number for the junction is? Need to try and chase up some prices, etc.
    Not sure sorry as a mate hooked me up with the part/install.
