1st gear is quite low. Sixth on the other hand is still within the useable torque range of the engine. I have done 2nd gear starts and wound out to around 7000 with ease. It can surprise many.
As I had an Outback, I looked at B4 and WRX before the Bora -all different vehicles -depends on your purchasing mood at the time but the quality of the VW & drivetrain refinemenet, is a cut above the Subs.
Fuel consumption is about the same - slightly higher I believe for the WRX.
I will be upgrading but keeping the Bora as a testimony to its engineering and enjoyment it has provided. The test of a good car is when you can jump in a couple of years later and still feel good about it.
