Page 6 of 26 FirstFirst ... 4567816 ... LastLast
Results 51 to 60 of 260
Thread: A long time coming, Rob's 4motion turbo build!
  1. #51
    Jan 2011
    Rooty Hill, Sydney
    Yeah keep up the good work mate.
    thats quite a good pace you got there despite work an uni !
    anyways youv gone further an quicker than anyone else has in this period of time. (feel free to correct me on that anyone)
    Garage:
    VR6
    XR6
    R36
  2. #52
    Sep 2009
    Ok so as usual long delays between updates, but first some photos from progress as of late. Much more progress has been made since these photos, unfortunately i dont have many more progress shots as i've been getting into doing it when i've been working on it and simply forgetting to take photos!
    (Now you see it) Turbo Roughley mounted up (its now properly mounted and hooked up, oil, water etc)
    Turbo... What turbo???
    After having battled with it for near an hour it gets pretty heavy
    mmmmm clean
    mmmmm spec stage 3+ clutchey goodness
    Off you go
    ARP goodness
    Dump pipe goodness, now all finished but again no photos unfortunately, eagerness once again getting the better of me!
    Open wide (think this photo was somewhere from early on in the build)
    Well thats all the photos i have, as i've mentioned a lot more has happened since these were taken. I'll update the progress in the next post!
  3. #53
    Sep 2009
    Ok so i'm not sure where i left off, i think i'd mentioned i had the head back on suspension, gearbox etc.
    Anyway a fair bit has been done since then. I've finished up the dump pipe and front pipe so most of the exhaust is now hooked up. This is one thing i'll almost never do again that said. Making a dump pipe in a shed with a car only a foot and a bit off the ground is not easy, having to guess then cut, get under car line up, mark, take to welding bench ( an old desk lol) tack, take back to car, test fit, repeat this process half a dozen times and there's one weld done...
    Turbo is mounted up properly and intake is bolted up btw which is a pain in the ass to do. The C2 motorsports short runner intake is a very nice piece of kit, however getting the bolts that hold the manifold on is an absolute pain in the ass to do up. Took around an hour just to bolt on not to mention the difficulties in fitting the throttle body, routing the vacuum lines and sorting out where everything went.... anyways done and fixed now!
    I also bought a Mocal oilcooler kit with thermostat from Bahn Brebner motorsport. To install this you sandwich it ontop of the standard oil/water cooler, its a tight fit but patience and time and it all fits, hopefully it should keep the oil temps down as the vr6 is known to run pretty hot even when standard.
    Injectors have been installed and plugs re-wired, this was pretty easy, just a note if installing a short runner intake leave putting the fuel rail on till after mounting up the plenum, otherwise you've got to take the bloody thing off to get to the plenum bolts Many 's like this have happened
    I also received a nice package from ECS the other day. A dual column pod with newsouth oil pressure and boost pressure gauges colourmatched to the factory dash.
    I chucked the ecu i received from C2 in tonight and just to solve my curiosity to see if it would work (call me a pessimist) and a turn of the key and the dash lit up lots of warnings though but only expected things like a warning for no coolant, oil etc but to my joy no imobiliser light, hopefully it'll stay that way when i attempt to start it!
    Anyway thats where we're at. Its pretty close to being done, hopefully startup day will be sometime next week! Stay tuned!
  4. #54
    Nov 2006
    Largs Bay, S.A.
    Posted at 3.20am - you really are burning the midnight oil on this build! Looks like you've made a lot of progress - can't wait to see it fired up.
  5. #55
    Sep 2009
    Yup gotta find the time somewhere!
  6. #56
    Jan 2008
    Newcastle, NSW
    Awesome awesome work mate. Congrats on ripping into it, can't wait to hear about the drive!
  7. #57
    Sep 2009
    Got cracking on the upper section of the cooler piping today
    Like the C2 intake manifold which is at the front of the motor, the piping will also be sprayed black and i'll either try and spray the silicone couplers or I'll just get black ones. Stealth FTW
  8. #58
    Nov 2006
    Largs Bay, S.A.
    Quote Originally Posted by WhO View Post
    Got to love it when it looks like it came from the factory like that.
  9. #59
    Sep 2009
    Awwww yeaaahhhhh though it was all ghetto'd up with no exhaust, a temporary intake temporarily held together by tape, no coolant and no oil cooler thus an oil system slowly draining the sump to an old oil bottle (but still making enough oil pressure due to the sandwich plate having the thermostat)....
    I can conclusivley say that Houston we have ignition!!!!!!! (only ran very briefly to be safe)...... awww yeah baby!!!! Now to de-ghetto it, finish it up and have a proper startup, warmup and rev
    The sound of that turbo spooling even just on idle.... ohhhhhhh i cant describe how much awesome it contained
    < go on... try and wipe it off me
  10. #60
    Sep 2009
    I WILL post video hopefully mid next week of it running off of the front pipe, the sound is just too delicious to not share!
