Results 1 to 10 of 12
Thread: Locating parts for mk4 golf
    Jul 2015
    Wanted to ask if anyone knows the best place to get a replacement master window switches bezel, specifically beige.
    Cant seem to locate any online that suit RHD, is there somewhere I can get one that's genuine if its not too expensive or non-genuine.
    Also, where do you guys get parts for genuine/non-genuine, any online stores or just a local dealer?
    cheers
    Munno Para West Adelaide
    Try the uk ebay mate, rhd cars over there and will prob get it over there.
    Jul 2015
    Quote Originally Posted by dubster99 View Post
    Cheers, had a thorough look but oddly most are for LHD from China :/
    ECSTuning is LHD too so I'm not sure where else to look.
    Whats wrong with it? Does it just need repainting?
    Jul 2015
    Yeah pretty much. Would prefer to buy another if possible over doing it myself.
    Jan 2014
    Adelaide, East Side
    Paint is your friend Locating parts for mk4 golf
    Sourcing grab handles as such is not worth the expense as they will wear exactly the same as the ones in your car now
    Even if you get them second hand from a wrecker they will have the same problem with the peeling rubber trim and or cracked woodgrain if you have it
    You can grab a kitchen scourer and scrub all handles to get the rubber coating off
    It does improve them by a lot and you can then hit the plastic with some protectant like armorall
    I done that with my shifter surround but I'm currently in the process of refinishing all of my door handles
    First picture is primer putty and second is after a coat of black
    It's a tedious process but will be good once it's all done
    __________________________________________________ ______
    MK4 GTI - Reflex Silver - <<<Click for Build!<<<
    -Previously Owned a MK4 1.6L Golf - Reflex Silver
    Jan 2014
    Adelaide, East Side
    All mk4s are the same and is to do with the terrible rubber paint they use for trim pieces Locating parts for mk4 golf
    Jul 2015
    Hmm that seems do-able I guess. Is there a colour mixing code to find for the beige colour?
    Just spray can, right?
    Jan 2014
    Adelaide, East Side
    I wouldn't have a clue with the colour man
    But yeah I'm only using spray cans from supercheap/repco
    Even if you hit one handle with a scourer to get the rubber coat off you can see what it looks like
    That rubber finish has to be removed completely before painting as the paint won't stick very well to it and will end up causing much more hassle than what you set yourself out with
    I ended up using paint from bunnings, satin black. Warm water with scourer does wonders with removing the peeling rubber.
    Heres mine I painted satin black
    I went a different approach with my interior and did a diy brushed aluminium affect
