Results 1 to 5 of 5
Thread: Link extenders for sway bar
    Hi all, I'm just curious if any of you know where you could get extenders so your sway bar isn't basing against the drive shaft after your car has been lowered?
    I'm looking at getting a new sway bar but I thought I'd look into these too as there is little difference with a new sway bar up front - or so I've heard...
    Quote Originally Posted by Whubbsie View Post
    There is nothing better than a polo badge, thats why you will notice Veyron drivers with polo gti badges.... they know where the true sizzles at!
    Mar 2007
    sydney
    Quote Originally Posted by 99gti View Post
    i also tryed this before fitting h&r bar trust me it dont work i hads custom ones made they were a lot longer than std, the prob is the bend over the drive shaft on the std sway bar, save your pennys and replace the bar very much worth it.
    mk4 the mods begin for round 2 hahahha
    Ahh, I see. It was just an idea but now you mention it, that would probably only make the link rub against the drive shaft wich would then defeat the purpose.
    Geometry 1.01
    Ahh well - sway bar it is. I hope my shoelaces hold in it's position for a week or two untill I get a new one.
    Dec 2006
    My car doesn't run against the drive shaft with the swaybar and the links ?
    In a conundrum now, will have to give Derek or Guy a call to see how much the links are as my bushes are dryer than the Gobi desert.
    -DIDZ
    Mar 2007
    sydney
    Quote Originally Posted by DIDZ View Post
    i just put the vf end links in they use poly bushes much nicer
