Results 1 to 10 of 20
Thread: Legality for LED front fogs
    Sep 2012
    Safety Beach, VIC
    Hi all,
    Just a quick question as to whether LED front fogs are legal on a Mk4 Bora. I already have HID headlights but i've got away with them for a good couple of months while the cops are blitzing illegal mods...
    Thanks, Josh.
    Pacific Paradise QLD
    Quote Originally Posted by Wighty654 View Post
    Hi all,
    Thanks, Josh.
    Can I politely ask that if you already have illegal headlights you are worried about the same for fogs.
    As its now illegal to use foglights other than in inclement weather why worry about changing them.
    Sep 2012
    Safety Beach, VIC
    Yes I am worried about the same for the fogs because the lights are legal with the correct equipment (sefl levelling motor and washing system) but i dont have them. If LED fogs are illegal I'll stick to halogen or similar so as not to draw attention to the lights on my car.
    I understand its illegal to use them except in inclement weather however every second holden (including the police down here) use there fogs all the time. That would be one law id be willing to break because it doesnt involve pulling things apart to fix, just a simple flick of a switch
    You talking about fogs in the headlights I lower grills?
    I had a cop try to hand me a fine for the lower led lights, but go out of it.
    I'm with above though, if any part of the car is illegal the rest generally doesn't matter
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
    Thats like saying they are legal if you dont use them. LOL
    Quite simply they are illegal as fitted.
    I would ask a lighting expert whether the LED "fogs" Or "Wan*e"r lights as they are known QLD are efficient for what their purpose is.
    That is providing the correct light in FOG
    There are also "running " lights as in the Passats which are not fogs but could be construed as such.
    I never turn them on as have LED DRL
    Sep 2012
    Safety Beach, VIC
    So is that a yes LED fogs (lower grille) are illegal or a no they aren't?
    I already have inbuilt fogs in the HID headlights I bought.
    Might just play it safe and go with a decent set of halogens with the same colour light as the HID(or as close as i can) but make sure they are aimed properly.
    Aug 2011
    melbourne
    to use 'fogs' regardless of bulb is illegal unless weather permits, which in Australia is rare. drl's must be wired correctly and of the correct bulb type and luminous rating. having said that, after market drl's look tacky as hell.
    just because you've gotten away with annoying as **** headlights for a few months doesn't mean you are safe. a fisherman doesn't catch every fish.
    Apr 2008
    When talking about those requirements, you're talking about HIDs, not LEDs.
    And they're not legal (even if you meet the other requirements) unless they were fitted as a factory option on the same chassis. Luckily, the Mk4 Golf R32 had HIDs and shares a chassis designation (1J), so you're covered there.
    You're talking about driving lights here, totally different kettle of fish.
    Nothing to see here...
    Nov 2010
    Burpengary, Queensland
    Not sure if this is applicable to MK4 Bora, but you could fit LEDs to a MKV GTI fogs and code them to act as DRLs. Legality, not sure. A QT inspector told me that the main reason for making the use of fogs illegal was due to people fitting high wattage globes to their foglights. Also, some cars eg certain Jeep models, are fitted with twin rear fogs which are as bright as brake lights - very annoying following one at night.
    I think you are confusing fogs with Daylight Running lights.
    I have never seen HID with fogs built into them. DRL yes.
    Maybe some do but I havent noticed them as havent seen any fog in 10 years so no need for them to be on.
    It is not illegal to have lights in the lower grille but it IS illegal to use them contrary to the regulations.
    EG FOGS are only allowed in diminished light, extreme rain and foggy conditions.
    They are not to be used as " LOOK AT ME" lights which 99.9% use them for and for which they serve absolutely no purpose.
    Fog lights in the past when they were really FOG lights had a YELLOW light.
    The reason is that white light gets reflected back off fog and you cant see at all especially if you try full beams.
    Yellow light cuts through the fog far better but doesnt look as good when used as W**ker lights
    Nowadays they stuff anything in usually white more for looks than usefulness and call them fog lights.
    All they seem to do, because they are poorly focused is annoy oncoming drivers.
    The lights you say you see on the cop cars are often classed as "other lights" (Not drivng lights which are different again ) by manufacturers to get around the Fog problem.
    The Passat has similar but are low wattage and dont annoy oncoming drivers like those in Falcons and Commodores
    One poster on another forum wanted to light up the area behind his headlight beams and just in front of the car. WHY!!!!!
    If he didnt see it with the headlights would be too late afterwards. Cant believe some of them.
    Leighaus's post says it pretty well and there was a thread on here recently that quoted the regulation regarding colour temp and luminosity as well
    HAve a read of this for a start http://www.racq.com.au/motoring/cars...ets/headlights
    and this
    http://www.vicroads.vic.gov.au/Home/...vingLights.htm
