Something different for a mk4 gti. The pic looks like it protrudes further than what it does. It's a korr lighting xdd380. Loose a bit of spread and distance because of the mounting position seeing as it's low to the road but still get a great amount of bright white light to 300 metres. It's not overly bright seeing as it's only 72 watts (compared to the 240 watt bar on my landcruiser) but it powers over the high beam. Mounted to the steel bar behind the front bumper. Just had to trim the bumper slightly for the mounts to slot into to get the bottom bolts in, and trim the middle insert to fit back around the light. Live down the back of the mornington peninsula so needed a bit more light for the darker roads and to spot the wild life before they end up being a bonnet ornament. Not concerned about fitting a fmic seeing as I'm soon about to fit a custom made bar and plate smic.
Was thinking about doing this too...
