Results 1 to 10 of 13
Thread: Leaky R32
    Nov 2008
    Northern Sydney
    Leaky R32
    So after all this rain in Sydney my R32 has developed a bit of a wet dog smell inside. Upon digging around, the rear seat drivers side footwell carpet is damp.
    I've sourced this to come from when i am parked next to the kerb at the slight camber that is in most roads. the water seems to fill up in the sill and when it fills up enough it flows over the top of the sill into the rear footwell.
    First of all does this happen to anyone else?
    Any suggestions for a solution?
    The history of my car is pretty good and as far as i know and the people who have worked on it it has never been involved in an accident.
    2010 Skoda Octavia vRS Wagon
    Dec 2007
    Brisbane, Southside...
    Have a look for some drain holes and/or bungs that may have come lose in that area underneath the car. Also I don't know if it will cause it but if you take out your wheel arch lining (front and rear), you can develop a massive build up of dirt and crud in there over time which may cause a blockage or maybe a backflow of water.
    See this post here for what I'm talking about (ignore the widowmaker ):
    http://www.vwwatercooled.org.au/newf...0&postcount=62
    Cheers,
    Trent
    2010 Renault Clio RenaultSPORT 200 Cup 20th Anniversary Edition - #19 of 30 - The French Connection...
    2004 Volkswagen Golf R32 MkIV - #044 of 200 - Gone But Not Forgotten...
    "Racing is life; Anything that happens before or after is just waiting." - Steve McQueen -=-=- "Si Vis Pacem, Para Bellum" - Unknown
    Nov 2008
    Northern Sydney
    Thanks Trent. I'll check the bungs but i am almost certain it is the building up in the door sill that is causing the problem. I'll try take some pictures tonight.
    Jun 2009
    Southport, Gold Coast
    does your car have sunroof ? if so check the drain tubes on the a-piller when door is opened.
    also check the pelum chamber for dirt build up each corner . it draines behind wheel arch trims like trent said
    does the air con excess water drain on floor/road ? check drian rubber gromet on fire wall rubber sometime sticks itself together.
    Authorised Superchips/Bluefin Dealer
    V A Garage - www.vagarage.com.au
    Aug 2007
    Perth, Australia
    [QUOTE=vagman;457342]does your car have sunroof ? if so check the drain tubes on the a-piller when door is opened. QUOTE]
    Aussie spec MK4 R32s never came with a sunroof.
    I never had a problem like this with my car. Maybe the drivers door seal (the rubber thing around the door) is worn. Wait till it dries out, get a garden hose and spray the drivers door. That should show you where the water is coming in and where its going
    1991 BMW 318is RED E30
    Feb 2008
    Auckland NZ
    my GTI golf use to do the same thing,
    Ended up under the Raintray cowling, on the drivers side is a single vent covering the ECU and all the Cars wiring. It had a slight leak, So when it filled up on the right side, it would then seep in slowly, then go under the carpet and fill up from the rear.
    Hope this helps.
    Audi S4 (2001) - Imola Yellow
    Secret Project
    Nov 2008
    Northern Sydney
    Pics as promised...
    The water is 'pooling' just above the oval shaped hole in this picture where you can see some dampness.
    The seals all look good here on the door...
    When the water pools it seems to go over near where the middle of the silver bar is
    Aug 2007
    I suggest use a second party. Hose the car down for a fair while and sit inside and watch for ingress.
    Jmac
    Alba European
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by Jmac View Post
    Jmac
    yes i agree with this method....strange problem thou
    Dec 2008
    I had a leak in the rear foot well on my passenger side in my r when there was heavy rain. Problem was the seal in the pollen filter housing. Such an annoying problem. All fixed now. There is a thread floating around somewhere on it. Good luck mate.
