Page 3 of 3 FirstFirst 123
Results 21 to 27 of 27
Thread: KVW100 Window Roll Up/Down Flash Load Module
  1. #21
    oh i see, this must be what the latest ones do. the earliest ones didn't even have a deactivate function. it was just activate and then throw it away.
  2. #22
    May 2012
    Perth, WA
    Quote Originally Posted by kapowww View Post
    .If you have the 1C0 comfort control model do what I did and buy an el cheapo VagCom/VCDS cable
    Thanks for the tip! The cheap cable and czeck software just worked on my 2003 golf. Didnt get a connection with my first attempt, but I took a brave pill and pushed the cable connector in with some more force and all was good after that.
    2003 Mk4 Golf V6 4motion
  3. #23
    Jul 2010
    Elanora Heights, Sydney
    The czeck software and the KVW100 failed on my car.
  4. #24
    May 2012
    Perth, WA
    Quote Originally Posted by PranK View Post
    Thought I would mention it just in case, since I made this mistake initially. You need to turn the ignition to the second position, not just radio on, but get the dash to light up with all of the warning lights etc.
  5. #25
    Jul 2010
    Quote Originally Posted by work View Post
    From memory, I think I tried everything, off, on, acc, start... But, keen to get this to work, so will try it again.
    Thanks!
  6. #26
    Jun 2009
    Melbourne, VIC
    Thanks!
    Is your car failing to connect to the program, or is the program connecting but not working?
    If it's not connecting then you have to test to make sure you can connect via VCDS-Lite and have the appropriate drivers. Then it should work with the program.
    VW Bora V6 4motion
  7. #27
    Jul 2010
    I cant remember, its been a long time since I tried.
    I know the KVW100 just gives me constant beeps, which is bad. But I cant remember what the app said. Will try it again and see.
