Results 21 to 30 of 40
Thread: knocking noise from front passenger wheel.
  1. #21
    May 2010
    Perth
    Bent strut dude, I've had the same problem more than once on different cars, everything else is the after effect.
    '76 Mk1 LS
    '04 Mk4 .:R32
    '09 Audi S5
  2. #22
    May 2012
    With the inner cv housing, it tends to wear out and cause play, and this play is evident when accelerating and coasting. Inner cv's cannot be tested by full lock, only way is to change them. No guarantee that this is the problem but I had this in my Mk3.
  3. #23
    Quote Originally Posted by type 17 View Post
    hmm but wouldnt it make noise all the time? or atleast when the wheels a turned either way?
    Quote Originally Posted by Eman View Post
    yeah pretty sure its CV or bearings now.
    Swapped wheels and hardware over and sound is still there. cant see anything out of the norm in regards to hubs/brakes/driveshaft
  4. #24
    May 2012
    The inner cv is always running straight, never turns........maybe the slight angle on a bump etc. They most times never make a noise. If u take the cv boot off you will notice round burnt marks on the metal cv housing from the ball bearings over heating. that is a sign that they are worn.
  5. #25
    Feb 2010
    Launceston, tas
    Sounds like axle bind to me, try losening your engine mount bolts and try shifting your engine to the drivers side. Might not fix it, but it's a free solution. Worked for me.
  6. #26
    well Volkwerke went over lots of things on the car.
    doesn't seem to be a bearing, subframe bolts are all nice and tight, only 1 control arm bush has just split.
    so currently thinking cv joint or just my coilovers just getting old.
  7. #27
    Aug 2009
    ACT
    You gonna have it sorted for nats?
  8. #28
    Quote Originally Posted by ffoff View Post
    ill just drive it
  9. #29
    Feb 2010
    Seaforth, NSW
    You better
    2014 Golf GTI PP - Pure White
  10. #30
    Apr 2015
    Queensland
    Did you fix the problem? I have the same knocking on mine
