Page 1 of 4 123 ... LastLast
Results 1 to 10 of 40
Thread: knocking noise from front passenger wheel.
    hi all,
    just lately iv been hearing a knocking noise from the front passenger side of the car.
    at first it seemed to be when i turned right at speeds between 5 and ~30km/h
    but in the last week or so it seems to be also when accelerating between 5 and ~50km/h (nothing when coasting or braking from what i can tell...)
    the noise changes with speed (faster i go, the quicker the knocking).
    it honestly reminds me of when i had stock wheels were on and the bolts started to come lose...
    have tried turning on full lock (was told this is the way to test CV joints) and heard nothing.
    I have trouble replicating the sound at the best of times (when people are in the car to listen).
    Going to pull the wheel off and investigate on Wednesday but would like some more ideas on what to look for?
    am currently running adapters but they are 100% hub and wheel centric, correct bolt seats, and i checked the bolts but they seemed to be done up fine.
    might throw a stock/different wheel on also and see what happens.
    Cheers, Dylan
    Jul 2011
    South-East Brisbane, Queensland
    I know it probably wont help but when I put my coilovers up one weekend because I was going for a long drive I got the knocking a lot at similar times to you, once I lowered them again I was fine and dandy. So maybe its your car telling you to lower it?
    Dan!
    v5 Bora/Indigo Blue/Remus sports exhaust/JOM coilovers/Lots of DIY bits and Pieces/
    Aug 2007
    Perth WA
    Could be the inner guard has popped out behind the wheel (engine bay side) and flapping against the tyre? Has happened to me a few times, I can pop it back in now just on full lock, except I've lost one of the square bolts now ...
    '04 BMP MkIV R32 #144
    search getnew
    Jul 2007
    Brissy
    It could be a CV joint.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jun 2009
    Melbourne, VIC
    $14 Pedders suspension check.
    VW Bora V6 4motion
    Erskineville, NSW
    top strut bearing or one of the lower control arm bushes?
    Northern Beaches
    I've got the same problem. Don't know what it is, possibly the sway bar. Still need to investigate further.
    Is it more of a bang or clicking?
    Jul 2007
    Brissy
    Quote Originally Posted by kapowww View Post
    Probably a good idea.
    But they failed to find what the twang noise was in my left front when reversing on full lock, it still there after a full suspension refresh too.
    MK4 GTI - Sold
    Quote Originally Posted by Brisbane's Bora View Post
    bhahaha best!
    Quote Originally Posted by geoff_gti View Post
    most of my arch and engine liners are gone... did think about this but then surely i would hear it on full lock
    Quote Originally Posted by JustCruisn View Post
    any other way to test other then the full lock method?
    well bushes have been gone for a long time, and have had R32 top struts in for about 40,000km... so couldnt imagine they would have got worse and strut tops should still be ok for a little longer...
    Quote Originally Posted by VDUB-BUD View Post
    I dont have a sway bar so one less thing to investigate.
    more low pitch thumping/clunking
    thoughts about the pedders check, but im also due for a service so might get them too suss it out at the same time.
    can anyone suggest any other 'tests' for the CVs?
    is there a noise for when tie rods are on the way out, or do they just get sloppy?
    iv done two CV boots on my drivers side and continually bash the frame on the drivers, so thought it would have been there that went first... not my passenger...
    Jan 2010
    west melbourne
    all be it a different model, my golf made the exact same noises (noisiest under acceleration and up hills as well as with a passenger), changed both cv's no more noise. not sure of any checks you can do
    Driving the coal. Low and rattly.
