Results 31 to 40 of 40
Thread: knocking noise from front passenger wheel.
  1. #31
    Problem just went away like it came from memory. Cv hasn't been touched, struts and control arms were changed but was a while after
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  2. #32
    Jun 2008
    Cronulla, NSW
    Bumping up 'cause my silly ugly loud/slow Bora is making a feral noise from what appears to be front right (but definitely front susp somewhere). Its a flapping noise at any speed like a bit of cardboard or plastic flapping) but I have checked the plastic aero stuff. I don't have a belly pan guard and most of my wheels guards are gone or chopped off so nothing is hitting the tyres.
    I suspect something suspension related, but the wierd thing now is that when i downshift to 2nd the car gives a shudder and sounds like something dragging on the ground...
    Sorry to throw up such horrible adjectives but its the best i got.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
  3. #33
    mount or something not broken?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  4. #34
    Jun 2008
    Cronulla, NSW
    I am thinking either engine mounts, dogbone (common fault and likely given how much of a pounding i give the car) or possibly something worse.... How to check engine mounts?
  5. #35
    get someone to load the car up and see how much the engine moves around would be my bet.
    both reverse and forward
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  6. #36
    Jun 2008
    Cronulla, NSW
    amazingly, all engine mounts incl dogbone are fine. Freaking thats 258,000 kms on stock engine mounts with hard driving and a chip for alst 100,000 kms.
    Anyway, turns out left front wheel bearing has given up on life and has 1.5inches of play lol. Hopefully the hub is ok.
  7. #37
    1.5"!!!!! how are you alive?
    Bora gone
    Vento VR6
    MKIV GSW TDI
    7P Touareg TDI
  8. #38
    Jun 2008
    Cronulla, NSW
    dude he said it was insane lol but out on the road all you can her are rather faint clicking noises. Drives true (slightest pull to left if anything) and accelerates and brakes in a straight line. Have done at least 1,500 kms on it lol
  9. #39
    Jul 2007
    Brissy
    How could the bearing move 1.5 inches, it is barely that big to begin with.
    Maybe 1.5mm ??
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
  10. #40
    Jun 2008
    Cronulla, NSW
    no no, the bearing was so shot I had 1.5in on play in the top of the tyre. Car was up on a hoist and old mate moves wheel, wheel has 1.5in play. Hence bearing giving up on life.
