Strut top bearing and bush would be the first point to check.
Open the bonnet and see how high the tops sit above the strut tower, there should be a little gap, but when the bush fails the gap opens
Hey guys just after some help, a few days ago i strange knocking sound started on the left side(thats what it sounds like) but its only when i got over a speed bump or bumps in the road will it happen..
What i mean is when the shocks get extended while going up.. If anyone has had this happen or could help out, you are a legend!!
But i do have an idea its the shock itself or the strut bear, maybe even my bushes..
cheers ned
-Silver 94 Golf mk3 R.I.P
-mk4 GOLF 2L- daily&project
"If I fitted 4x100 to 5x100 adapters and then a 5x100 to 5x112 adapters... would I die?"
I've had the same thing since installing ground control camber plates, mine is on the right side tho and sounds almost like the springs are knocking around
'02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
