Results 1 to 4 of 4
Thread: Knock Knock
    Aug 2011
    Westside bitches, Melbourne
    Knock Knock
    Hey guys just after some help, a few days ago i strange knocking sound started on the left side(thats what it sounds like) but its only when i got over a speed bump or bumps in the road will it happen..
    What i mean is when the shocks get extended while going up.. If anyone has had this happen or could help out, you are a legend!!
    But i do have an idea its the shock itself or the strut bear, maybe even my bushes..
    cheers ned
    -Silver 94 Golf mk3 R.I.P
    -mk4 GOLF 2L- daily&project
    "If I fitted 4x100 to 5x100 adapters and then a 5x100 to 5x112 adapters... would I die?"
    Strut top bearing and bush would be the first point to check.
    Open the bonnet and see how high the tops sit above the strut tower, there should be a little gap, but when the bush fails the gap opens
    Nov 2012
    Melbourne, VIC
    I've had the same thing since installing ground control camber plates, mine is on the right side tho and sounds almost like the springs are knocking around
    Aug 2011
    melbourne
    That's next on my to do list, right after
    boost leak test &
    rubber for my wheels
    '02 GTI (clicky) - REFLEX SILVER - VIEZU race tune. VAR design 2.5inch stainless steel dump pipe with 100cell cat into 2.5" billyboat stainless cat back, Forge TIP, N75, Audi DV, ghetto CAI, FK-AK s coilovers, tunerdone LEDs, Clarion CZ301E sound stage.
