Results 1 to 9 of 9
Thread: Key/Remote Help
    Nov 2006
    Largs Bay, S.A.
    Does your car have the sensors for remote operation mounted inside somewhere? Not sure where they are from the factory, but perhaps the interior light or in the front pillar region and near the rear window ... I thought key/fob remote was standard on GTI's in which case you'd just need the fob and a suitable key blade to cut and code.
    If you know someone with VagCom, they could scan the car and check whether the module for remote central locking is present and functioning.
    Best Wishes.
    Northern Beaches
    I think your best option is to get a remote locking system like this eBay Australia: Buy new & used fashion, electronics & home d installed and place the RF chip from the original remote into the new remote/key. Then get the HAA key cut at your local lock smith.
    Mar 2010
    Quote Originally Posted by RolfGolf View Post
    Best Wishes.
    Thanks Rolf, this sound sensible.
    Quote Originally Posted by VDUB-BUD View Post
    As above, I don't really want to install this if my car has remote central locking from the factory.
    If anyone knows where I should look for remote central locking sensors in the car that would be awesome. Or if anyone knows when the changeover to remote central locking happened... I have it in my head that pre 2001 GTI's didn't come with remote central locking.
    Cheers again,
    Alex
    Mar 2010
    Bump in case anyone else has ideas...
    Dec 2008
    Sydney/Canberra
    Your best bet is to go to a dealership, and quiz the parts guys on it.
    The parts catalog will indicate which keys are applicable. From memory, the GTIs had the larger flip-out key with remote.
    You can order them pre-cut from VW to suit your car, according to your VIN number. Then, when they turn up from Singapore around two weeks later, arrange for the service department to program them for you. They're around $400 each.
    '07 Transporter 1.9 TDI
    '01 Beetle 2.0
    Jul 2007
    Brissy
    If you don't have the flip remote key then you don't have factory remote locking. The sensors and hardware will not be in the car.
    That ebay kit looks like a good option. There is a DIY on VWVortex for a similar kit.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Northern Beaches
