Results 1 to 7 of 7
Thread: Noise in dash
    Jul 2010
    Noise in dash
    Hi,
    I am hoping someone would be able to help me identify a noise that is coming from the dash on the passenger side (it is most prominent under dash).
    It started intermittent but goes consistently now.
    This is the sound
    Jul 2007
    Brissy
    It could be an air flow flap motor. Motor 71v or some such.
    Does it go away if you press the re-circ button ?
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
    Jul 2010
    Quote Originally Posted by JustCruisn View Post
    Yes it dose go away when re-circ is pressed. Can you tell me any more about it (easy/hard to replace etc.)?
    Thanks
    Jul 2007
    Brissy
    So the noise is an ac flap motor. Probably motor v71. The motor moves to a predefined position, gets a fault, the system tries again, it gets a fault, the system try again....
    There could be a problem with the motor cogs etc or the flap movement may be getting blocked/stuck or their may be a wiring issue.
    You should get a proper VAG COM scan to tell you which motor it is. There are several. v70 & v71 are common.
    Knowing my car and the problems with things made of plastic I reckon its likely to be the cogs or a broken arm to the flap itself.
    Some older threads
    http://www.vwwatercooled.org.au/f14/...w-38653-3.html
    http://www.vwwatercooled.org.au/f14/...e-33628-2.html
    This vid shows the flaps moving, you could check this yourself but removing the pollen filter ans looking into the air intake.
    YouTube - Air Flow Flap Positioning Motor (V71) Golf IV
    A bit more info from 01274 - Air Flow Flap Positioning Motor (V71)
    The design and therefore repair is different from LHD to RHD, so the Bentley guide is not going to help too much. A replacement job looks fiddly and time consuming.
    Expect to pay about $200 for the motor. Part number 1J1 907 511 A.
    MK4 GTI - Sold
    Jul 2010
    thanks for the info
    Quote Originally Posted by nathgti View Post
    Hi,
    This is the sound
    Justcruisin seems to have hit the nail on the head with his detailed reply but for me it:
    sounds like one of these stuck under your dash!
    Jul 2010
    Quote Originally Posted by CustomSpooling View Post
    Had a look but could not find one haha
