Results 1 to 5 of 5
Thread: k04
    Aug 2007
    doncaster, vic
    k04
    Hey guys,
    Probably draining the hell out of the k04-22 (the 2000 TTQ R had the APX motor) (from an audi TTquattro) questions but, does anyone know or where can i find out
    How much bigger than the standard k03 found in mk4 gti?,
    Ie what percentage more air does it flow?
    thanks
    MK4 GTI|REVO|4BAR ADJ FPR|APR FMIC|APR R1 DV|TURBO INLET PIPE|KONI|WHITELINE|CUSTOM CAI + K&N|2.5" TB + HI FLOW CAT| ECS DOGBONE
    Dec 2006
    http://www.seatcupra.net/forums/show...97&postcount=1
    Grabbed that from another thread in the search function.
    -DIDZ
    Nov 2006
    You won't be able to use the turbo of an S3 or 4wd TT - It won't fit.
    Iirc the exhaust housing is different on the FWD/4WD models (Ontop of north south/east west engine mouting differences)
    Aug 2007
    doncaster, vic
    Quote Originally Posted by SoVeReIgN View Post
    arggh...!!!
    Dec 2007
    Melburg East VIC
    try searching here:
    http://forums.vwvortex.com/zerothread?id=2941200
    unfortunatelly its not a bolt on like the k04-001
    have to change the mani, downpipe, injectors...and since you already have REVO you could get the program upgraded to run this, prob dont have the code for aussie ecu but worth asking.
    apparently it pulls a lot harder than the bolt on k04
    pro-imports sell the kit or seperate parts
    1.8T AGU | K04 | GIAC | 380cc | VR6 MAF | Custom Intake | FMIC | TIP | 3bar FPR | N75J | 42DD 3-2.5" TB | GFB DV | FK Highsport | ECS Stage 1 Clutch | OZ FUTURA
