Page 9 of 10 FirstFirst ... 78910 LastLast
Results 81 to 90 of 97
Thread: just picked up R32 #42 :D
  1. #81
    Aug 2013
    sydney
    dog bone bushings went in today with out any mechanical hassle, i did buy the wrong torque wrench yesterday and get another one delivered, but besides that went in with no fuss. its not a huge amount of difference but you can feel it, for me engine braking has been the biggest improvement.
  2. #82
    Aug 2013
    sydney
    so after doing some poking around with my fuel problem today i dicovered that i had unknowingly tapped the fuel pump fuse #28 when i put my 3way flapper switch in. swapped it out to another spot and now i have key priming which is good. worked out my dorr micro switch is the problem for auto priming, never elaised because lights always come on cause i use the key so now micro switch diy time
    but no, since my drive home from work, i get a weird gurgling noise when car car is hut off, i assume its fuel return, but its a weird noise i have never encountered from any car. i recorded on my phone to post in here but cant seem to work out how haha. any thoughts on this one?
  3. #83
    Jul 2007
    Brissy
    Is your fuel tank really full ?
    I notice gurgling noise when very full, it goes away after driving 60km or so.
    MK4 GTI - Sold
    MK5 Jetta Turbo - Sold
  4. #84
    Aug 2013
    sydney
    thanks cruisn! you were right, it did disappear. and now so did my key priming on the pump lol. from what ican find on the interwebs it seems my relay and micro door switch are both cactus. i checked out a couple of diys for it but im cbf to stuff around with the power windows and all that jazz.
    anyone had this done at the stealership? any idea on price to replace door lock module? ill swap relay and fuse my self, relay is already in the post
  5. #85
    Jul 2007
    Brissy
    Quote Originally Posted by 2times View Post
    You are not going to like the answer.
    Lock from dealer will push $300 easy, then labour at $150+ per hour.
    There really is no messing with the power windows. Once the door card is off you need to loosen the window reg bolts, drop the window down a bit and pull the glass out of the door frame.
    Next undo the 2 star bolts for the door module - you need to get the correct tool.
    Unplug all electrical connectors.
    Undo all the 10mm bolts around the door insert.
    Pull the whole inner plate off the door frame, it will still hold the lock module, window motor and slides, speaker etc.
    A simple test for the lock module - when you open the driver's door does the interior light come on, does the light at the bottom of the door come on ? If both of these are OK then I'd say the lock is OK.
    I know that when reassembling the door trim, once I plug in the bottom door light connector it triggers the fuel pump. So maybe check that 1st, if you get interior light but not door light then check the bulb for the door light.
    MK4 GTI - Sold
  6. #86
    NSW, Sydney
    Have you checked fuel pressure regulator? That controls the fuel return.
    On Mk4 it is on fuel rail but Mk5 is near the filter I'm pretty sure.
    If that's faulty you won't have any pressure at the injectors it will just go back into tank.
    Could also be.... The fuel circuit starts and ends at the pump, so that's where I'd start my investigation first.
    It could be the anti drain-back valve sticking partially open, hence the poor fire up time and the noises.
  7. #87
    Aug 2013
    sydney
    Quote Originally Posted by robbie View Post
    i initially thought it was a fuel return problem because of start up, but im pretty sure it is just relay and door switch related because the car runs fine and the pump doesnt sound weird or anything once it starts up.
    Quote Originally Posted by JustCruisn View Post
    oh man, thats a bit much. do they really charge 150 an hour? i might see if exotic cars can do it, they did my timing chains and i was happy with their work. ill call them monday and try to get a quote.
    im not getting any door light, or interior lights when door is open nothing what so ever happens haha. so door micro switch is most likely kaput. im going to check the wiring i messed around with when i did my flapper switch just to make sure i havent severed anything. but atm nothing happens when doors opens.
    i know the relay is gone also. when i pull out fuse #28 and replace it i get key priming but only once it doesnt happen again. so when circuit resets the relay goes back to its normal position and its fine once current is apllied it locks done again and doesnt go back to normal position so i know that is gone too.
    step 1 check wiring, step 2 if wiring is fine gets quotes because im lazy.
    but another question, im most likely going to replace my MAF also in the coming months if this fuel scenario doesnt fix my economy, are the bosch and oes maf's ecs have as good as a genuine one? or is it important to fork out the extra pennies for vw maf?
    it was my understanding bosch was a good reliable brand? but theyre the cheapest?
  8. #88
    Aug 2013
    sydney
    did some more investigating today. all the wires i messed with trying to do my flapper switch are still soldered together so theres no issues there. there is a couple more problems i discovered aswell, which is really effing irritating!
    firstly, next to relay 409 there seems to be a missing relay? is there supposed to be something in this spot? if so, what does it do, and which relay is it?
    next problem is i randomly have oil like stuff on my drivers side grill. i have no idea where it came from? or why its there? i pulled off the grill to find somesort of drain hole looking thing there with what looks like to be old oil. am i missing some sort of bung or what? and does anyone know why there is oil like stuff there? is it coolant or powersteering fluid or what? i checked my fluids today and nothing is running low... this is both worrying and confusing for me?
    any help will be much appreciated!
    merry christmas
  9. #89
    Mar 2009
    That threaded hole is for the tow hook mate
    Oily residue could be just spilt coolant etc?? I don't think there are any oil lines running in that area so it wouldn't be that..
  10. #90
    Jul 2007
    Brissy
    tow hook thread, the oily stuff could be old thread lubricant.
    That area of the car collects all kinds of crap, when it rains you'll get oily water forced in there from the road spray. The water will dry, the oil will stay and collect dust etc.
    Give it a good degrease and clean it off, see how long it takes to get mucky again.
    MK4 GTI - Sold
