Originally Posted by
JustCruisn
You are not going to like the answer.
Lock from dealer will push $300 easy, then labour at $150+ per hour.
There really is no messing with the power windows. Once the door card is off you need to loosen the window reg bolts, drop the window down a bit and pull the glass out of the door frame.
Next undo the 2 star bolts for the door module - you need to get the correct tool.
Unplug all electrical connectors.
Undo all the 10mm bolts around the door insert.
Pull the whole inner plate off the door frame, it will still hold the lock module, window motor and slides, speaker etc.
A simple test for the lock module - when you open the driver's door does the interior light come on, does the light at the bottom of the door come on ? If both of these are OK then I'd say the lock is OK.
I know that when reassembling the door trim, once I plug in the bottom door light connector it triggers the fuel pump. So maybe check that 1st, if you get interior light but not door light then check the bulb for the door light.
