Page 50 of 54 FirstFirst ... 404849505152 ... LastLast
Results 491 to 500 of 536
Thread: Jlt-r32
  1. #491
    May 2009
    North Brisvages
    Sorry mate can't help with tooling.
    What you going to run on rear as your BBK ?
  2. #492
    Townsvegas QLD
    Quote Originally Posted by Big_M View Post
    This plus brembo 1 pot ebrake calipers and adapters are good to go now just want to double check with the brake dust sheild and then I can get some new ones cut.
    SLAM.POKE.TUCK.DROP.DOPE!
  3. #493
    Townsvegas QLD
    So I'm on revision 4 of the mounting bracket (thanks Steve for the milling)and everything lines up and bolts up correctly, So now I can get some new brackets laser cut out of one piece of metal instead of 3. Now I'm waiting for some 315mm rotors to show up. So in the mean time I need to bead blast the brembo ebrakes and rebuild them and then paint all the rear brakes.
    Got another set of rear brake lines fabbed up so I can run them from the 4 pot rear caliper through the rear trailing arms to the hard lines. Ohh and the shop foreman approved the upgrading in braking.
  4. #494
    sydney
    Nice jay , hydraulic handbrake?? Ohh maybe not as there probably plumbed in line with the main pots.
    I would have gotten wood from the picture message you sent me.. But I was sniffing Nitro, so i already had it. Hahaha.
  5. #495
    yeah what on earth is that for, some ghetto security mod?
  6. #496
    Townsvegas QLD
    Quote Originally Posted by alex g View Post
    No hydraulic hand brake. The brembo e brakes use the oem brake cables. Just the main calipers are hydraulic but it would be sweet to have a spilt hydro ebrake.
  7. #497
    Townsvegas QLD
    Quote Originally Posted by McDub View Post
    what is your question.
  8. #498
    sydney
    Was thinking that , would be easy to do , get on it. Lol
  9. #499
    sydney
    You know you want it.
  10. #500
    May 2009
    North Brisvages
    Looking good man.
    A hyd hand brk umm………….
