Results 1 to 10 of 536
Thread: Jlt-r32
    Townsvegas QLD
    Cleaning the engine bay turned into this
    Ok I'm kidding I got around to putting the clutch (spec stage 3+) in along with a new To bearing hyro assembly and thought I take the motor out to just so I can check everything out.
    So needless to say Im upgrading a few things since the motor is out. Which has turned into bead blasting a bunch of crap and painting everything gloss or matt black. I think I'm going to do the engine bay gloss black that way its done for later on when the car gets a full respray.
    Anyone know where 1 could get a diff installed at?
    Figured I would detele some stuff in the bay and move some other stuff around to make room for some water/meth.
    I'll try to take some pics along the way
    Cheers Jay
    SLAM.POKE.TUCK.DROP.DOPE!
    Jun 2008
    Cronulla, NSW
    man, you must be getting very quick and proficient at dumping the engione and drivetrain out like that on a relative whim. Gold.
    Looks awesome too.
    MY02 Bora V6 4Mo|Matte Black plastidip|VTDA|R32 Exhaust|R32 dampers and springs|TT pedals|R32 steering wheel|17" 8L S3 rims|R32 sways|Blue Haldex|EBC reds
    Townsvegas QLD
    I put the new clutch and To bearing in and Lucas helped me install the tranny to the block and torque everything up.
    Started with the engine bay
    Oct 2006
    jeebus!
    i think ill be needing a new clutch soon if i keep launching so hard lol
    Sep 2006
    Australia?
    Damm I love you americans <3
    May 2009
    Townsville,QLD
    [QUOTE=Mr. JLT;541736]Cleaning the engine bay turned into this
    Hmm I was gonna call and ask if I could borrow your ramps..I take it your using them
    2009 125TDI Passat
    2002 B5.5 1.8T Passat
    Townsvegas QLD
    I hate snail mail;-(
    In the mean while, bead blasted a few more things and painted them gloss black. Reinstalled the short shifter and parts back on to the tranny and ordered a set of shifter bushings( http://www.42draftdesigns.com/catego...ngs.html)since I already have the mounts. Had to rethink where I'm going to put the P/s reservoir. Still at work for another hr and then work out and then get to the garage..
    Aug 2007
    Perth WA
    '04 BMP MkIV R32 #144
    search getnew
    Mar 2010
    brissy
    Cheap as chips, too! *order*
    2011 TDI Caddy- AirRex x AccuAir setup.
    May 2009
    North Brisvages
    Did you order some Drew ?
