Page 15 of 54 FirstFirst ... 5131415161725 ... LastLast
Results 141 to 150 of 536
Thread: Jlt-r32
  1. #141
    Nov 2007
    Coffs Harbour
    Quote Originally Posted by Mr. JLT View Post
    I could have gone 8:1 or 8:5:1 but I didn't want it to be a phat big off boost,
    So 9:1 is good for me and I may pick up rods,clutch,diffs later when want to run over 20psi but I'll wait till I get back to the Us to build a forged bottem end.
    ok all sounds ok! wat hps will you get at 20psi? or wat psi will you start from?
    JVL
  2. #142
    Townsvegas QLD
    I'm going to start with 10psi and work my way up but no more than 18psi until I get home and build a forged bottom(rods,pistons/rings,Apr or sms rod bolts. The 630cc injectors max out at 18psi at 100% duty cycle and thats 536Hp to the wheels. Im going to start with 440cc injectors and run them at 80-90% duty cycle and see how that goes. If I'm not happy with Unitronic software I'll switch to the C2 500 program
    SLAM.POKE.TUCK.DROP.DOPE!
  3. #143
    Nov 2007
    Coffs Harbour
    so you have some serious head work done?.....
  4. #144
    Jun 2006
    Orange NSW
    Nice build mate.. Love it.
  5. #145
    Townsvegas QLD
    Quote Originally Posted by JVLR32 View Post
    Nope-head work and cams are usless at those power levels- I thought about head work and cams before I talked to Alex@Vagmotorsports and told me dont waste my money, Since I was going FI he would help me build my kit for the R since they have built alot of turboed R32s and the shop cars for Unitronic-he said head work and cams are more for if your going to keep the car Na.
  6. #146
    Townsvegas QLD
    Thanks mate I cant wait to get it finished up- and do my part to help the economy with all the fuel I'll be wasting
  7. #147
    Sep 2008
    Townsville
    Maybe less drinking beers and sitting round b/s'n and more workie on the R
  8. #148
    Nov 2007
    Coffs Harbour
    Interesting....you would think havin the heads breathing nicer that the turbo would spool easier....eg.
    like you running around the block with a straw in you mouth an then swapping using a condue pipe...i know which one i would rather breath through
    nice stuff JLT anyways
  9. #149
    Townsvegas QLD
    wheeew got some parts in.. I cleaned the head all up a few weeks ago and just reinstalled it with a C2 head spacer and new head bolts,gaskets. I installed the exhaust manifold and turbo and wastegate. Im waiting on a oil relocation kit for the oil feed line to the turbo inlet port and my pullies. I'll start bending the hard lines for vac, oil , water tomarrow and install the vac block.
  10. #150
    Oct 2006
    all ive done is gearbox on hoist and gearbox out!
    keep the updates man, some pics?!!
